nissan patrol gu st-l
I have a problem with the throttle response- drove the car found it had no go past 3000rpm and took its time getting there.l parked the car for a day then drove it with no problems at all - - once again drove it following day same issue - slow response (eg top gear 60kmph floor it no down change ) l then removed the airflow censor from the air cleaner (check replace) made no change but no the engine light stays on- any susgestions
I cleaned the maf last weekend, started it without the maf plug on and it revved to 3K.
Put it all back together and the engine light stayed on.
Left it overnight and it has gone out.
Go figure?
All good now
nissangu
The car has entered its "limp home mode" for some reason. it will need to be plugged into a scantool to find out what is causing the problems. Cheers
mmm...the car still drives as nothing wrong - full pwr (with engine light on) but l agree it needs to put on scanner
