after about 5 years of my passenger side engine mount being broken i finaly decided to fix it , but i didnt want to spend the cash on another engine mount only to have it break again , which seems a lot of people seem to do, i remembered someone on here drilled a hole through the middle of one and stuck a bolt through it so i figured i will give that a try
so i removed the engine mount and motor braket all in one , i found that the thread on top and the pin on the bottom of the rubber part are just studs pressed in , so i just pressed the old ones out , which is easy as my engine mount is already broken, ie : the top plate had seperated from the rubber , to get the bottom stud out i had to drill a hole through the rubber which i had to do anyway, i then got a long bolt just a tad smaller than the hole and fitted it in from the bottom with the thread up top, the problem i had was the head of the bolt wouldnt fit into the hole in the chassie , so i ground the head of the bolt so it will fit into the triangular hole in the chassie , (if i could have gotten a drill in to the chassie mount drilling it out would have been better), i then added a shocky rubber on top then a washer then the nut ,
i then loosely assembled the engine mount so the bolt still had plenty of play up and down, fitted it all back in , bolted it up, tightend the bolt through the middle to put tension on the rubber and now i have an unbreakable engine mount
as mine is probly the original engine mount it was a bit squashed , so i added a strip of rubber to the original rubber so there wasnt any metal on metal anywhere
