1 - 1 of 1 Posts
Hi guys,
Hoping you guys can help.
I'm replacing my front engine mounts on my GUIII zd30. (as part of a bigger engine overhaul presently....)
I've tried a couple of things so far.
With the motor and clutch housing still attached, both the top 17mm and bottom two 14mm nuts removed, lifted the motor as far as possible (until it comes in contact with the firewall tunnel), but this doesnt give me the clearance to remove them.....
I've dropped the tranny cross member while performing the action above and this still doesnt help.
What am I doing wrong here?!? :(
I would really like to avoid removing the engine brackets if possible, they look like a problem getting the four 14mm bolts back on after the new engine mount is in place.
Thanks guys
1 - 1 of 1 Posts
