Handbook states 5.7 ltrs. Ive put this amount in and its not touching the dipstick. Its a 2000 zd30. I didnt measure what came out but would guess approx 8ltrs. Im now wondering if the correct dipstick is fitted.
fill to the dipstick mark. 8 plus litres is the revised fill amount, someone else can probably advise the actual amount.
8.2L with filter change on my 2002 zd30.
I think earlier zd30 had different (longer) dipstick and lower oil change capacity but Nissan soon revised this after oil starvation issues. Instead of redesigning sump and oil pickup, they just increased oil level!
Sent from my SM-A705FN using Tapatalk
Done. It took as you say 8.2ltr. Half way between high and low on dipstick. Cheers
GUII ZD30DI Wgn
You would be amazed at what you can find in the archives we spent so much time putting together.
