CARIB... i see what you are saying and normally it makes sense, but i did try running a colder thermostat early on and all it did was to make the motor run hotter on the hwy, i even tried drilling holes in the thermostat to get more flow but all it did was make it worse, this is when a light bulb lit up in my head and i thought " if a colder thermostat is only making the motor run hotter when on the hwy , then a hotter thermostat should make it run cooler on the hwy" well that was my thinking at the time, so i got myself a 91 deg thermostat, and yes it did run hotter around town (about 10 deg) but it did also stop the temp from getting really high and also kept the temp more stable, which is was what i was after in the first place,
another side effect of running the hotter thermostat was the clutch fan wasnt locking up like it did with the colder thermostat and all i can work out is that the coolant must be traveling slower through the radiator and not needing the fan to draw extra air to cool the coolant, and yes the fan is/was working properly
look at it this way... the greater the differance between the coolant temp and ambient air temp the easier it is to remove a certain amount or percentage of heat given the same amount of airflow
so , lets say with your 82 deg thermostat being just open , it is passing say 20 liters of coolant p/m (eg. only) and the engine fan is drawing 100cfm of air and the ambient air temp is say 32 deg , it will only remove a set amount or percentage of heat , to remove a higher amount or percentage of heat you need to change one of the figures above, increasing the coolant flow wont remove any more heat because the air flow also has to increase to keep up with the increased coolant flow, air flow would be fixed and cant change, running a colder temp thermostat would only reduce the temperature difference between ambient air and the coolant meaning it would remove a lower amount or percentage of heat, the only other option is to increase the temperature difference between the ambient air temp and coolant temp by fitting a hotter thermostat, the greater the difference the greater the percentage of heat would be transfered to the air
