1 - 3 of 3 Posts
guys if you want to install a relatively cheap engine saver as the name sugggests, this cant be beaten.
i was just about to set off down the beach at rainbow beach towards Teewah when a slight buzzing noise could be heard.
i initially thought that it was on the radio but then the visual light started to blink.
i pulled over and sure enough my coolant was low.
upon further investigation one of my heater hoses had worked its way loose and was bleeding green.
a few litres of coolant and a quick tighten up of a hose clamp and we were on our way.
i imagine if it had of leaked the coolant out as it was and i relied on the temp gauge then damage would have been done.
so this easy to install gadget has paid for itself and then some........
It's all good
Good that you had it on and why did you get it from ?
Hi sorry for the late reply.....
Low Water Alarm Sensor
it is dead set the best protection money can buy.
definately should be added to the NADS program.
1 - 3 of 3 Posts
