hey guys a got a erps electronic rust protection kit for "large 4wds" for pretty cheap, its brand new and has 8 contact pads. has any one on here installed the electronic rust protection their selves? if so wheres ideal spots to put all the parts on a gu wagon, thanks for any help guys
1 in each door, one under the bonnet, one in the rear quater panel and one at either end of the chassis. the pads must only be placed on clean painted surfaces, advisable to place a bead of silicone around each pad once they are in place.
make sure all connections are water tight on the wiring, just the touch of the bare finger will stop the signal getting through.
only draw the power supply from the starter battery and not an aux battery, and if an older style unit ring erps and get them to send you a replacement inline fuse for it.
do all this and they do help aid in the prevention of corrosion. they are not a be all and end all, you still need to keep up with preventative maintenance.
