1 - 7 of 7 Posts
Hello all,
I am not sure if this has been done recently, I have conducted a search with no results so I have proceeded with this post.
I am attempting to collate an updated Error / Fault Code List to keep on my phone or a laminated version in my glove box.
I have extracted most of the codes and info from the ZD30 Y61 Reference Document v2.4 by AKSNISS and trawled through the forum for new additions.
If anyone has information on other codes or corrections to the list below please add it and I will upload the document once complete if anyone else wants a copy.
Fault codes
0087 Fuel Rail System (Pressure too low)
0089 Air in fuel System
0102 Mass Air Flow Sensor
0103 Coolant temp sender
0104 Vehicle speed sensor
0203 Throttle pedal switch
0208 Overheating Fault (Cooling Fan control)
0234 Turbo Over boost
0301 Engine ECU
0402 Fuel temperature sensor
0403 Throttle pedal position sensor
0406* Intake air volume VNC system
0407 Crankshaft position sensor
0502* Battery voltage
0504 Auto Trans communication line
0505 No faults detected
0660 Intake Manifold Tuning Valve Control Circuit (Bank 1)
0701 Injection Pump – cam ring position sensor
0702 Injection Pump – TDC pulse sensor
0703 Injection Pump communication line
0704 Injection Pump – spill valve
0705 Injection Pump – Circuit malfunction, poor fuel quality, Pump Control Unit Failure
0706 Injection Pump –spill valve
0707 Injection Pump injection timing control
0802 Engine ECU (Barometric Pressure Sensor)
0804* Engine ECU
0807 Stop lamp switch/circuit
0901 Engine ECU (calculation malfunction)
0902 Engine ECU relay (incorrect voltage from relay to ECU
0903* Engine ECU (internal signal processing malfunction)
0905 Turbo Pressure (Intake air pressure sensor)
1003 EGR volume control valve
1004 Injection Pump – fuel cut out system
1401 NATS locked
1402 NATS locked
1403 NATS locked
1404 NATS locked
1405 NATS locked
1406 NATS locked
1407 NATS locked
1408 NATS locked
* These codes do not illuminate the Check Engine warning lamp.
Apart from the docs you speak of there's also another link in the archives in manuals and papers electrical which has 400 pages of them :).
Geeyoutoo,
Found it. Thanks. There is some quality info there.
However, After going briefly through it all it still does not cover codes I have recently come across eg P0089 (Air in fuel). I was after more of an 'aide memoir' for use on the side of the road in the middle of nowhere. To assist in determining whether to clear the code and push on to civilisation or try and fix on the side of the road or get a tow.
If this has been done I wouldn't mind getting a copy.
Great idea I will print one out when its completed.
The two codes I get all the time funnly enough never made it to ur list . From memory its 401 and 740 which is the blocked egr and torqure convertor lock up switch
Does 0740 (Torque Convertor Switch) bring on the CEL?
Schanmala,
Thanks heaps. That is the type of info I am after. An understanding of the prefix letter of the fault code and break down of the categories will assist on the side of the road. Just need to find all of the manufacture specific ones. Not too many more to get I suspect.
Does any one have any knowledge/experience of any specific manufacturer codes not listed? I guess I'll have to go through the workshop manual a bit more thoroughly. I am specifically after
P00** and P1*** type codes.
Cheers,
1 - 7 of 7 Posts
