Thought I'd start a seperate thread for the engine rebuild instead of doubling the size of the car's build thread.
Blank first post so I can edit it later to summarise.
A rule of thumb is 0.001" play per inch of bore and bearing diameter, give or take a little depending on how it will be driven.Now onto the not so great news. It might've seemed above that I can just buy all new genuine gaskets for the engine, give it a good clean inside, put it all back together, and have a recently rebuilt engine all well and good, but that's probably not the case.
While the top end has clearly been rebuilt, Dad's suspecting that the bottom end hasn't been touched, or has been touched but put back together the way it was.
Basically, there's a lot of play in the pistons inside the bore, and the thing that worries him most is that there's a small amount of rotational play as well; as in, you can rotate the pistons slightly either way.
The other thing too is that it looks like the bores have been honed, but probably not much, as you can still see the honing marks all around the cylinder. Problem is you can also see some pretty significant scratch marks up the sides of each cylinder too, perpendicular to the crank and gudgeon pins. So it seems that the bottom end bearings, and/or the gudgeon pins, have some play in them. It also seems like after the bore was honed they either didn't replace the rings, or replaced them with standard size, not oversized ones to suit the hone, which could be contributing to the piston play.
If you rock the pistons side-to-side in the cylinders they knock against each side of the wall as well, not sure if this is normal but dad suspects this is where my engine had a noisier, knockier, and generally slightly rougher idle than the farm ute we've got.
Pics of the cylinder bores, and a video of the piston movement, to come.
Does that include rotational play? That's the bit that Dad said concerns him as that's to do with bearings, not bore, rings, or pistons.A rule of thumb is 0.001" play per inch of bore and bearing diameter, give or take a little depending on how it will be driven.
If you only have 0.001" play per inch of bearing diam you will get 2 tenths of bugga all rotational play out of that.Does that include rotational play? That's the bit that Dad said concerns him as that's to do with bearings, not bore, rings, or pistons.
Righto, I’ll get these photos of the bores soon and a video of the play, and measure it while I’m out there. But first, dinner 😁If you only have 0.001" play per inch of bearing diam you will get 2 tenths of bugga all rotational play out of that.
Yep, sump will come off tomorrow, I might start poking around the timing system as well to see how that all goes together and comes apart (worst case I forget how to put it back together and I look it up, the internet is a good thing), so hopefully then all the bolt-ons will be off tomorrow and it’ll just be a blank block with the crank, cam, and pistons in it, and oil cooler on the side. Then I’ll be able to see if the main bearings have much side-side movement with it all still assembled, and pistons out to inspect the gudgeon pins.A lot will be revealed when you pop a piston out.
Oh yeah, I’m well and truly aware of that,Don’t believe everything you see in those books. Be prepared to question things. They are a good guide, mostly.
Ed Zackery, can't have to many pics when your pulling things apart or making adjustments.Take pics of everything before you pull it apart and you won't forget how it goes together and load all stages to a portable hard drive.
Foo
