I forgot I said this 🤦♂️they've put a new head on this thing the last time it was apart, which is awesome news, I'm genuinely really happy about that, means almost no matter what else happens, this engine is going back in the MK 😁
Hey James, we talked at length with this guy over his lunch break. He was happy with the visual look of the bores but was a little worried they would be out of spec for round. There was plenty if evidence of blow by past the pistons (which is easy to see now he's pointed it out). We havent actually measured anything yet though.Did the engine builder measure the liner protrusion
Oh and another thing, he confirmed that the engine had been sitting for a fair while when he noticed the round marks on the big end bearings:Hey James, we talked at length with this guy over his lunch break. He was happy with the visual look of the bores but was a little worried they would be out of spec for round. There was plenty if evidence of blow by past the pistons (which is easy to see now he's pointed it out). We havent actually measured anything yet though.
With regard to how the liners are sitting, some of them look like they are in a little crooked. One side seems to sit proud of the deck whilst the other is dead level at best. There is also evidence of leaking past the head gasket in the really low spots.
He said we could bolt to back together with a new head gasket and it would hold up for a while but ultimately it would fail again in the same spot.
So without throwing a whole pile of cash at this block we are not sure it's worth the effort. It's done a lot of work as evident in the cam shaft bearings. They are really worn (I guess they weren't replaced the last time it was "rebuilt") One option we are looking at is finding a bottom end that's in much better condition. They come up from time to time here in QLD
Uneven liners are a new one, I've not seen or heard of that in an SD before. I suppose if one side has dropped or been over compressed that may have affected the roundness of the liner which would promote blow by. Perhaps that could be a result of the cylinder head being torqued incorrectly, or uneven clamp pressure. Or possibly severe overheating and the piston has dragged the liner?Hey James, we talked at length with this guy over his lunch break. He was happy with the visual look of the bores but was a little worried they would be out of spec for round. There was plenty if evidence of blow by past the pistons (which is easy to see now he's pointed it out). We havent actually measured anything yet though.
So without throwing a whole pile of cash at this block we are not sure it's worth the effort. It's done a lot of work as evident in the cam shaft bearings. They are really worn (I guess they weren't replaced the last time it was "rebuilt"😬) One option we are looking at is finding a bottom end that's in much better condition. They come up from time to time here in QLD 👍🏻
Could be a week, could be a year. Depends on how the engine was stored, what precautions were taken to prevent moisture ingress, humidity when in storage, how much moisture was present when the engine was assembled etc etc.Oh and another thing, he confirmed that the engine had been sitting for a fair while when he noticed the round marks on the big end bearings:![]()
Apparently those are condensation marks.
How long does the engine’s need to sit on a pallet outside covered by an open-front shed to get condensation all the way in the bearings? Anyone know?
Alrighty, went and got the new (half) engine yesterday, got a couple things to say about it.
Firstly, for $200, I got another injector pump, which is probably worth that on it's own, another crank, cam, block with (seemingly?) good liners, oil cooler, water pump, basically everything below the head, because the engine didn't come with a head.
The story behind this engine, is that it was in a Patrol with 460,278 kms on the odo, which a young bloke, bit older than me, bought as a parts car for his wagon. When he bought it though it didn't come with a head, and the P/O said he'd have to get the head back from somewhere, I don't remember where, and this young bloke could come pick it up a while later. Well he messaged the seller a while later and it turns out the nasty bugger sold the head on him, even though he paid for it, so he was stuck with the parts wagon with no head on the engine.
So he pulled the engine out, not sure what to do with it, and it sat undercover for about a year, with oily rags covering the deck, before he just decided to sell it. He's getting rid of most of his MQ parts anyway, we had a good long chat and I'll definitely be back over to grab some other parts. There's a brown MQ centre console that I was eyeing off the whole time 👀
He actually started up his wagon while we were there, it has 600 odd thousand k's on it, engine's had bottom end bearings replaced at 500ish, and it's never had any extra fuel go in or anything. It's been on 2 laps around the country before he bought it, and when he started it up it just purred like a kitten. I must be used to SD's that aren't in great condition because it didn't have any of what I now presume was piston knock against the liners that mine had, and none of the badly adjusted tappet noise that the ute has. Never had aftermarket gauges or anything in it, just completely factory engine driven like a car. I guess that's what happens when you leave well enough alone, it just lasts.
So anyway, now I've got 3 of these damn engines in the shed:
The new one on the stand:
View attachment 546640 View attachment 546641
The good thing about this engine too, is the block doesn't seem to have ever been decked, all of the galleries still have rounded edges, whereas on my old one they all had a sharp lip. There's also numbers that I can see in this block that I couldn't on mine, so they got decked out on mine, as well as numbers on the pistons. The pistons are marked "C2 T" and are in far far better condition than the old ones:
Here's a video demonstrating that there's no twisting movement in the pistons, but there does seem to be uneven amounts of movement when comparing 2 pistons. First is piston #2, then #5, which both sit on the same plane:
The bores also look better than mine by a long shot. They don't have the same level of honing marks in them, but they're probably factory if the rest of the engine is, and they only have barely visible scoring on a couple of cylinders, mostly ring gap scoring.
View attachment 546657 View attachment 546658 View attachment 546659 View attachment 546660
Continued in second post due to 10 file limit:
Nope. Here's a better pickIs that a crack in the second last photo?
Not that one...
Good pickup...Not that one...
This one
https://www.patrol4x4.com/cdn-cgi/i...4x4.com/attachments/1665324048759-png.546659/
Possibly a broken ring, seen that before.Good pickup...
It doesnt appear to be cracked but does have some decent scoring. It's by far the worst bore
Will need to pluck all the pistons and have a really good look
Is it necessary to hone all the scoring out or will it 'survive' with a light hone and new rings?Possibly a broken ring, seen that before.
Yes it will survive, if I'm reading you correctly you want to put this engine together at a good price. I suppose the question is how will the pistons look when they come out? if they aren't good then you will need to go oversize and the decision is made for you.Is it necessary to hone all the scoring out or will it 'survive' with a light hone and new rings?
I understand ideally you want it perfect but is it necessary?
Yes, the goal is to do it right, but as you say at a good price.Yes it will survive, if I'm reading you correctly you want to put this engine together at a good price. I suppose the question is how will the pistons look when they come out? if they aren't good then you will need to go oversize and the decision is made for you.
