Some info that may help u out.
Have only rebuilt a couple of engine. Mid 80's I did not have much spare cash (still don't lol) and from 2 x B series 4cyl NA diesels I built one up for my FJ45 swb LC (similar situation).
Sounds that your latest SD purchased is in reasonably condition. The crank maybe just a newer design _ just guessing.
I would hone of the bores, they do not look too bad and you may find those marks / scores are not that deep anyway. 4-6 passes most likely not enough but this is a diesel engine old school so give it a go. Could use an internal micrometer to check diameters (as you go), but if not readily available, maybe buy an internal telescopic gauge set (maybe more affordable) and then measure across points with Vernier (be pretty accurate). Cheaper Ebay jobs but this is an example of one that may suit. Just an idea:
www.tradetools.com
Agree, I would use the latest eng pistons (be determined after examination), first look at new std rings (ie:sizing), gudgeon pin and small end bearings may be OK, install new big end bearing (recon u would anyway), give existing valves a clean / re-seat and what ever else you think as you proceed.
You are all over this stuff anyway.
TradeTools | Huge Range, Great Service
Still have the hone tool that I used and is similar as you referenced (should be fine).. Just be mindful when drawing hone up, do not go past stone head pivot point or it will flip out of bore. Just keep moving up/down evenly and take your time. Plenty of Youtube stuff out there I am sure.So the next question I have then is if I go to supercheap and pick up one of these:
From what I'm reading just do 4-6 passes with it to get the cross-hatching back, I'll be able to use the same pistons and some new rings? Keeping in mind that I've found as James said earlier since liners can be bought I can't find any oversized pistons, so anything I do will be with standard sized everything. Just need to know if that will take too much material off to make it run like new with standard everything.![]()
I read a lot about taking too much material off giving piston slap, which is probably why my old engine was so damn loud at idle.
