Been a while since the last update so here's a quick one,
Like I mentioned in the wagon's build thread, I got the N/A engine in and running, it's slow, but not as bad as I thought, I'll update that thread in a sec as I got the exhaust sorted and drove the car for a couple weeks.
We're now on holiday down in country Victoria for December and part of January, so the engine rebuild will have to wait until then. Garry's been keeping me updated on the status of the head gasket, got the manifold gasket and crank seals a while back but it seems Nissan themselves are having trouble with this particular gasket. There's no stock available so they're waiting for the manufacturer to produce more, and the manufacturer says after the new year. All good though, gives me time to fully assemble the bottom end and get all the head work sorted, whatever needs to happen to that.
Been reading through
@bambill 's
The 350 killerwasps goal thread. An extremely good read so far, I'm definitely struggling to keep up on a lot of the technical turbo-related information. I am only 18 though, so I've got a lot of time to learn yet, it's just cementing in my head that the GT2052V will be a great match for the 3.3 given it works very well on the ZD30 (even slightly too small in some cases, not quite enough airflow up high) and the SD is a 12-valve engine, indirect injection, with a non-crossflow head, intake ports sharing manifold runners (similar to an old holden i6, but with no effort made to make air flow around the wall between the ports), the only thing the SD has over the ZD is it's extra 292cc's of capacity. Less than a can of coke. Maybe the 6-cyl trait is slightly more desirable for smoothness, but it's also trying to make power out of much smaller cylinders.
The GT will certainly be a huge improvement over the old HT, I'm still trying to work out whether a multi-valve VNT control system will work better than a single Dawes/tillux and needle valve, given that the SD's fuelling isn't controlled by airflow. If it has advantages even on an old mechanical engine like the SD, I'll go straight to that.
@james008 has told me that he knows 2 guys who tried this turbo on the SD before, both snapped cranks extremely quickly. However I believe that neither person understood how to control the VNT properly, and probably just used a single valve, keeping the vanes fully closed until desired boost was reached, and suddenly opening them. That would've created huge amounts of EMP at low RPM's (slow engine with more capacity, receiving almost full fuel straight away), leading to very quick crankshaft failure.
Most people increase the off-boost fueling to get the turbo spooling on the SD, I'll likely leave it as-is or even remove some off-boost fuel, as the VGT will spool well even with less fuel. Once the boost compensator kicks in it'll go hard I hope.
Gotta break it in before then though (gotta build it before then though), everyone's got different opinions about how that should be done, I'm going with the option of "drive it as you'd normally drive it, varying the load a lot, accelerating from a red light is good, not too high RPM's, load it up under hard throttle a couple times later in the break-in process.
Longer post than I intended 😅
