March 2022 Update: New Boots, Broken Hubs & Recovery Improvement
A few things have changed since my last post. I'm now settled into my house, and have had more time to go on trips and work on my Patrol out of my now (mostly) set up shed. I had an...shall we say interesting? New years trip, during which I did about $1500 of damage.
Long story short, the cheap aftermarket auto locking hubs I fitted packed up when I needed them the most, along with my spare one. I ended up attempting Callcup hill (longest continuous sandy hill climb in WA, possibly Aus) in 2 wheel drive, and with a lot of winching and help from strangers got 150m from the top before calling it quits. Not a bad effort I reckon 😆. I took the summertime track out and drove home without further incident, but the grand total of damage on the trip was:
- Rear left mudflap bent into and mangled by the tire; I unbolted it and binned it
- Winch rope snapped in multiple places (amazingly the old Grande still works, but it copped a flogging)
- Recovery damper got ran over and destroyed
- My cheap Tred recovery tracks were wrecked from overuse. They are also woefully inadequate when compared to proper Maxtrax.
- 3X failed front hubs (one factory, 2X ching-chong)
- A few tyre caps lost
- One failed reverse LED globe
So I got to repairing all of this damage.
I decided to fit a new kings winch since my old one did so well. Time will tell if this was a mistake or not, however what I will say is the new one is alarmingly lighter than the old Grande. At first I thought the body was made of GRP (plastic), however turns out it was just the powder coating finish they put on the steel. The winch solenoid box is not properly sealed like the Grande's, so I sprayed it with some Penetrene before mounting it to my Patrol. It took me about a day's work to take my bullbar off, swap winches, then remount the bar. I also took the opportunity to replace the remote control wiring I installed that runs from the winch to the hardwired switch in my roof console (it had corrosion tracking along the wires, probably from when they were disconnected in the months between installing my FMIC and modifying the winch braket to remount the winch). Having an engine crane made the job a breeze.
Prior to going on my new year's trip, I decided to replace my worn out and frankly dangerous Mickey T's with something new. I settled on the Maxxis Razr MT772's. They have good reviews, and let me tell you they copped a beating on that trip and are no worse for wear (including getting a 4mm steel bar pushed into the tread). After running them for 3 months or so, I reckon they are quieter than the MTZ's, however the wet weather performance is just as dismal. At least it makes for some fun sideways action 😉.
Next on the repair list was a way to positively fix the front hubs that worked only when they felt like it (and then not at all). I did want to replace like for like with the factory auto lockers as they were great for many years, but the extortionate ($1200AUD Each!!) pricetag on them changed my mind. I decided to keep it simple and change to hand operated manual hubs. The AVM units bought from Superior ($319) fit the bill without breaking the bank. They are a pretty simple design; there two concentric rings inside. The outer ring is bolted to the hub, and the inner ring moves toward the diff when the handle is turned, slotting into the outer ring and the axle. Not much to go wrong there, and let me tell you I was pretty over using a 22mm socket and the tire iron in my door pocket just to engage 4wd! Finally, I put a shiny new set of tire caps on each wheel that match the hubs.
After fitting up the hubs, I moved onto the mudflap. Nothing special here, I just fabbed up a new bracket out of some spare steel and bolted a spare mudflap onto it (good thing I bought four).
And last but not least,my special order blue Maxxtrax arrived, and I mounted them to my roofrack with some aluminium cladding strips. There was a bit of fouling on my awning mounts, so I made up some spacers out of scrap aluminum to make them clear the bracket and sit level.
In other news, I have discovered a practical use for my Victron 1200 watt inverter. I found an old miniature oven, and mounted it in my Touring Unit shelves by wedging some wooden blocks on top (it's temporarily permanent), and put a piece of thin aluminum sheet underneath to avoid melting the carpet. The result: A oven/grill built right into my Patrol. Now I can cook frozen food as well as expand my camp cooking repertoire, and let me tell you having a hot pastie or sausage roll ready to go after a long road trip is amazing 😀. The only downside to this however, is that because it's so power hungry (1250 watts!), I need to have the engine running and the bridging solenoid between the alternator/main battery and lithium system on when running it. There is however, a caviat to this, as the oven has a grill mode that only runs the top heating element, halving the power draw. My Lithium setup will run this on its own with no issues, however the temperature control is disabled on the oven in this mode, so food can burn if not regularly checked on. This isn't an issue when camping though.
I hoped you enjoyed reading this, safe travels!
