1 - 1 of 1 Posts
Nissan gu patrol
I have a extra cab 06 td42 which started out as a wagon and been converted to an extra cab and I have replaced the sub tank with a larger one out of a ute and the problem I'm having is that the sub tank pump isn't working and apparently it's the sender unit won't communicate with the sub tank module/controller has anyone else done this or recommend the best way to fix it. Was thinking using standard wagon sender and modifying float if that's possible
1 - 1 of 1 Posts
