1 - 8 of 8 Posts
Nissan patrol gq
Hi Guys just after a bit of info regarding fitting reduction gears. I have a short wheelbase GQ patrol 4.2 Diesel with manual transmission. I also have a AUX 50L fuel tank fitted in the usual position, its about 1 inch behind the transfer case. My question is can the transfer case be unbolted & then rotated to clear the AUX fuel tank or does the tank have to come out ?
THANKS for your Help.
Glasshouse Bogan #1
nissan patrol gu
Once its off the dowels it will rotate. Watch out the basta rd is heavy.
Glasshouse Bogan #1
nissan patrol gu
I suppose the dowels are about 10mm long so you have about 15.39mm to spare lol.
I think I would drop the tank
Nissan patrol gq
Discussion Starter #8
Thanks again Guys, I'm going to attempt it with the tank in first it's a pain pulling it out. LOL
1 - 8 of 8 Posts
