1 - 2 of 2 Posts
Hi Everyone, No indicators on Y61 2006 wagon fuses keep blowing...Suspect faulty flasher can Don't know where to find it...…..can anyone help please...
Thanking you in anticipation Urban Bushie
Normally a faulty flasher relay doesn't cause the fuse to blow. The Flasher relay is located below the radio on the right hand side. In line with your left knee when sitting in the drivers seat. If you look up from the clutch pedal towards the back of the radio you should be able to see the black rectangle plastic box. It's easier to remove the trim that sits above the pedals to access it.
Your short is more than likely in the trailer plug, rear tail lights or lights in the bull bar.
It it has a genuine trailer plug fitted you can unplug it just behind the drivers side rear tail lights and see if the short disappears.
1 - 2 of 2 Posts
