1 - 2 of 2 Posts
Hi, I recently punched a GQ with some stinky carpets. I've ripped the inside out and getting it ready for underfloor insulation.
my question is, I'm looking at buying a sound deading, heat proof and waterproof insulation. my plan is to fit Mass loaded heavy duty vinyl on this inside. but was looking at something really good to put underneath it.
Thank you
I just did half my car with car builders MLV which has a foam layer added. I did this as it can be removed if T get wet but don’t absorb water. So far I have the old carpet on top but will change up to vinyl flooring once I get the front part done. The product was ok to work with. Some puzzling to get the curves right. The only thing I would have done differently was the tape they sell. It works well and the glue they sell is really good however I ripped the tape when moving the vinyl around. I would probably just get some rubber/woven stuff from Bunnings and used that instead.
1 - 2 of 2 Posts
