1 - 2 of 2 Posts
does anyone know what size the lip is on a td42 flywheel is? mine is worn off and i need to machine one back on befor i fit my new clutch, so if anyone has there clutch off at the moment or a new flywheel in there shed could you measure the lip. it will be around 00.5mm or 2.00mm or somthing like that , you should be able to measure it with a steel ruler or the back end of a vernier caliper. thanks tim
nissan patrol y60
hab mine done the other day and im pretty sure it was 1mm
1 - 2 of 2 Posts
