1 - 2 of 2 Posts
Hey guys, know next to nothing about auto elec.
I was removing the previous owner's dodgy wiring, I came across a phone unit (hands free) disconnected that an noticed it had wiring from the phone unit up to some wires with single fuses... Followed that wiring and it branches into twoseparate wires, one to the ignition barrell an one to like a plug just above the driver's side foot well?
Should I remove this or??
Attached photos..
Goes into that cluster **** of wires and has a single fuse box (in black tape as it just sparked)
And then it runs back down (joined with a black wire now with a yellow fitting)
Screwed into the body...?
Sorry if it doesn't make sense don't even know Wtf the wires are doing..
Also, rev tachometer doesn't work, someone show me a picture where it's located in the engine bay so I can see it's connected?/what else could I check to see if it's still not working?
Thanks.
If you are no longer using the phone kit remove the wiring.
Probably power and switch power
1 - 2 of 2 Posts
