If you have drum fronts and want to convert them then just use MQ/MK/GQ stuff. All the same except the bracket that bolts the caliper to the knuckle flange.
If you want to swap your rear drums, then use whatever will work and has good parts availability. Nothing bolts on, so you'll be fabricating brackets, mounts etc anyway.
