ok,
first up i have a rattle in engine that has just started up recently, it comes in at approx 1800rpm and is gone by 2000rpm other then the noise no change at all in performance, oil pressure since i have owned car has been all over the shop (going off gauge, assumed prob dodgy) at times (idle when warm) shows nothing on gauge "O" when cruiseing some times around 4 others O when cold it is up i think round 5? 4? either way its the 0 that bothers me.
im thinking perhaps these may be tied in to each other? low oil pressure not giving head enough oil? caused damage?
also have a knock in the front end (yes have read all posts on this elsewhere) does mainly do it when vehicle is wet, seems to come from below the drivers seat area, sounds like something is loose or has play in it, have been under and checked tightness of everything cant find anything obvious really. no crack in floor seam that i could find, went right across seam.
any suggestions that i could check?
