1 - 7 of 7 Posts
nissan patrol swb gq
Got a question for all of you in the know
Can you put a LSD diff centre from the rear of a 1989 GQ into the front diff housing?
and if it can be done how hard is it to do?
No different size, front ones that fit are the rear LSD centre out of a pathfinder. Have a look at a work shop manual for what needs to be don't to replace a diff centre but it's not a hard job to do
the crownwheel and pinion are also designed to go the other direction. even if you mafde it fit there would be pinion bearing lubrication problems. search for "high pinion rear"
1 - 7 of 7 Posts
