1 - 20 of 21 Posts
4x4
Just wondering if anyone has made one or bought one.
I have a rhino rack full length on car, at the rear i have a space case that is as wide as the rack, and spare wheel. as you can guess, when driving at highway speeds the wind pressure is great, which means more fuel usage.
i have been looking on the net to see whats available, so far ive come up empty, has anyone made a deflector that sits on the front of the rack?
when i go on long drives (camping) ill have the rhino bag on the roof which will work as a deflector, but looking for something i can buy, or easily make to do the job whilst pottering around town and day treks that's easy to put up take down.
I thought of some plywood with a bracket to hold it up, but unsure if the wind would be too strong for that, thought about metal but thinking maybe to heavy to take down when not needed.
any suggestions?
I'd suggest alloy sheet, I had a piece of 3mm 400mm high across the front of my old roof rack, it worked really well.
nissan patrol gu4.2
I just went to an engineering joint that worked with aluminium and got them to make one and tech screwed it on
LED ZEPPELIN
1995 GQ TD42 NA
don't have pics here, will chuck one up later, I made my own roof rack, the front sides were angled back, I followed this line with the alloy sheet, and had a cross brace at the top.
Y61=WIN
Since I know a thing or two about stuff like computational fluid dynamics and I have had some very bored episodes at work lately I plugged some very basic models and it came up that if I stuffed around doing a front spoiler in front of the roof rack, that everything else was so wrong aerodynamically I dont need to bother when doing highway speeds
We just need to accept our vehicles have the aerodynamics of a flying brick and get on with it
Nissan GU1 4.2
Photo.?
nissan patrol gu4.2
Haha yep that's about it I reckon!
I had a sheet of perspex on the front of my TJM rack on the GQ - it was vertical but extended down almost to roof level.
I didn't really notice any difference BUT when I took it off the rack after a bird strike wrecked it I noticed a distinct increase in wind noise.
And the Tracklander I've got on the GU has a 'spoiler' on the front and there is very little wind noise with the rack on.
FWIW
obi 1 patientnewby !
I put my Maxtrax up there. doubt that it does much as a wind deflector, but it keeps a lot of the bugs of the gear and roof top tent.
Before I put these pieces in the solar panel would get wind under it at flap about.
I also had an mq shorty I built a canopy and built a deflector that came down to the windscreen and pop riveted it there so there was no gap at all and have to say if there is even a 30mm gap between the bottom of a deflector and the roof and doesn't follow the curve of the roof the advantages will be very minimal
nissan gu 4.2tdi 2003
i made three roof bars, two for the RTT and an adjustable wind deflector for the third! 6mm Polycarbonate sheet, its about 5 years old so looking a bit tired and ready for replacement. works well and you can feel the difference without it with the tent on.Michael
1 - 20 of 21 Posts
