G'day all
I have recently purchased a 2005 GU 3.0 Lt Patrol manual & am still getting my head around the basics for regular maintenance. Through this forum I am OK on the oils for engine, transmission, transfer etc and so far so good.
I am having a bit of trouble with the fuel filter. Repair manuals from Ellery’s & Gregory’s recommend 2 different ways to remove and replace the fuel filter
1st Option; is to disconnect the hoses, disconnect water sensor wiring connector, remove the bolts retaining the filter housing to the bracket & remove filter assembly.
2nd Option;Disconnect harness connector on the warning switch, drain the fuel from filter, using a filter wrench remove filter from vehicle, remove sensor from the filter
Questions:
Looking for advice on which is the best option - space around the filter is a little tight
If option 2 is the go, how do you drain the fuel from the filter?
An aside but related to fuel filter …..
Am heading to the Gibb in July and was wondering if I need to fit an water separator (Responsive Engineering | Water Testing System | Diesel Filtration | Water Watch - Water Watch System) in the fuel line in addition to the standard fuel filter. Not sure if an additional filter will reduce fuel flow and cause problems.
Appreciate any advice
Questions:
