Hey guys,
My RB30 has been giving me trouble again. Started cutting off while driving.
Now it can't be started at all.
I had a look and pretty much immediately realized it's an electrical issue.
It's dual fuel. The problem happens with both LPG and petrol.
Basically, electricity isn't getting into the fuel system solenoids.
If I give a direct connection to petrol solenoid it fills up the carby and starts without issues.
I'm pretty sure it's the same with the LPG, even though I didn't do it.
I had close look all this late arvo, but couldn't find any broken wires or weak earth points.
Checked all the fuses. They are fine.
So, I reckon it's either an earth issue or major wire is broken or corroded somewhere in the fuel system.
It has an immobilizer, which is working ok. Not sure if it has anything to do with this.
Basically, no problem with engine cranking and other electrics like lights, etc.
What is the best way to find the culprit?
Any tips, leads, advice will be gratefully appreciated.
Thanks guys.
Thanks guys.
