1 - 2 of 2 Posts
Hi again mates,
So i´m really close to buy a td42t engine.
Which rd28t´s parts dont fit in td42t like water pump, alternator, steering? I just have no idea..
Hope for help,
Regards,
Francisco
Parts needed will be:
complete engine/gearbox/clutch/flywheel and accessories from TD (power steer pump/aircon/alternator etc)
Engine mounts
radiator and hoses
tailshafts
Exhaust (may be able to modify the existing one)
diff flanges (can use 2.8 shafts and retain diff flanges if the transfer case is changed to one of RD)
Accelerator cable and pedal
Unless you are handy with wiring a custom loom from someone like Killa Kustom Kables would be handy
Might want to consider diff gears as well if you don't plan on running big tyres as the TD will be revving with 4.6 diff gears
Good luck with it, i had the conversion done for me but sourced all the bits.
I didn't dislike the RD but having an engine with torque is great :)
1 - 2 of 2 Posts
