1 - 20 of 40 Posts
Rear view
Sent from my SM-N981B using Tapatalk
Hey mate, welcome back, remember many conversations with you, funny, only thinking about you a few days ago.
GHMBC #3
nissan patrol gq lwb,3"lift.
Been a busy few yrs.new business,moved etc.still got patrol collection.Had to put the original Gq out to pasture- got too beat up haha
GHMBC #3
Discussion Starter · #11 · (Edited)
Nearly done.Keas reverse pattern mechanical 4th valve body with PCS push button gear change.may add paddle shift later. Marks 304 to re4 adaptor arrived.magnum hd 8 bolt flexplate.box done.just need Austral Torque 3 plate lock up converter.gearbox cost is 12k.total cost will be just over 50k
GHMBC #3
Discussion Starter · #12 · (Edited)
Front bar.
10mm chassis plates
8mm winch cradle
100x100x5mm top shs
89x89x5mm middle shs
75x75x5mm bottom shs
Cut out for trans cooler scoop.2 derale coolers with twin spals under winch
GHMBC #3
Discussion Starter · #15 ·
Few mods to 304 coming up
Twin 70mm throttle bodies on VN manifold.
Twin blos lpg SU type mixers
Custom air intake
Ice ignition - full kit
Davies Craig 150 EWP & controller / factory waterpump delete cover
Engine Watchdog tm2 - monitor engine and box temp also control fans on trans cooler
Relocate alternator
Astra electric power steering pump
Block timing chain oil gallery for better oil pressure
Larger sump/pick up
Stainless performance exhaust
Will change cam for towing/lpg if needed
1 - 20 of 40 Posts
