1 - 3 of 3 Posts
nissan y61
You may wanna check the belly plate behind the water pump. The vain goes at the back or it cavitates. most people think its a head gasket. If you done all the test , compression etc and it all comes back good then this will be the problem.
Real common on Patrols from 97 to 04.
Belly plate can be replaced real quick or if it just cavitation use metal epoxy sealant and fill in.
1 - 3 of 3 Posts
