Fitting up some dual analouge/digital gauges temp,pressure boost egt etc.
My electrical knowledge is basic.
There are 4 wires to each gauge, earth, lights, ignition, battery - fairly straight forward.
My question is:
Can the ignition and battery wires just be spliced together to run off the ignition sourced wire. If not I presume the battery wire need to be a "live" source.
I guess the battery wire is to keep alarms set, which I dont plan on using anyway.
My question is:
