1 - 2 of 2 Posts
HI all the L28 gear box to a sd33 i know there is a difference but the centre extension in the SD33 box can this swap into the L28 box.
It's about 100mm difference so the tail shaft fits and all bolt on the mounts.
Is the front shaft same ? All is it that will not fit at all.
Thanks in advance if anyone could some light on it be great.
MK Wagon, and an SD33T in pieces...
When you say the centre extension, do you mean the extra bit Nissan added on the end of the middle housing for 5th gear?
1 - 2 of 2 Posts
