Reworking Airbox Lid
In
THIS thread OldMav mentioned a small mod that could be a 1%er, I did the mod as best way I could given the time before going on my road trip, a quick test seemed to give better response, but the long trip through various terrain showed something else. I have my main water meth injection point coming on at 16psi (it is not set up for performance, more for economy) my usage rate is generally 0.9 - 1.0L/100k highway and 1.5-1.9L/100k off road and mountainous terrain. Just finished a trip covering all these situations and found the usage rate has dropped to 0.5L/100k on highway and 0.75L/100k off road and mountainous terrain. So it looks like efficiency has improved via the mod, I still can't believe such a small thing could make that much difference, it means the boost is sitting just under the injection point for longer. So I have had to make minor adjustments to spoolup to compensate
Water Meth Injection Changes
Before leaving on my trip
@OldMav and I had a conversation about WM injection theory, Peter had come across a proprietary study which changed the way WM is thought about, seeing as my DI is going and always open to ideas a test was decided upon. Peter may come in so I won't go into to much detail on what happens, but will show what I did and how the test has gone in the last few days since doing the first part of the mod the day after I got home.
We have thought that pre turbo is a highly efficient method of injection, this may not exactly be the case, injecting into the entry of the IC apparently has many good points, which I can partially prove in my trials at the end.
I have disconnected my Pre Turbo injection (but still in situ at the moment). Earlier tests indicated that Snow nozzles atomised better than Cooling Mist, so it was Snow nozzles I machined and fitted to the turbo inlet. I have numerous nozzle brands so am fitting Cooling Mist to the IC entry as follows.
The second part of the paper was something we already knew but more difficult to do on a DI, and that is injecting straight into the inlet manifold, very difficult on a ZD30 and particularly on a DI as the throttlebody is the last common point for feeding all 8 valves, once you get to the manifold the tracts are separate all the way to the left and right valve banks so you only inject into 4 valves instead of 8, it is extremely difficult to make that happen without a lot of machining or making a new inlet manifold, neither of which I'm inclined to do, so for the present my second injection point will remain at the TB.
Yesterday afternoon I did a run up the highway towards Gympie then turning back after 30 minutes 104k in 5th and in cruise. The interesting thing is that there are 2 climbs on that run that will consistently see my EGT climb to 400c, yesterday it didn't go past 350c on either and it lost no performance because of the removal of pre turbo. What appears to be happeneing is that the injection of WM into the IC opening is not so much cooling the air but cooling the IC which in turn cools the air.
I'm impressed, this will put new airbox on hold while I rethink my setup and finely tune to optimise.
