WM Nozzles into Inlet Manifold, The Real Deal.
Got my AN4 bits, pulled IC and Throttlebody off yesterday and started the WM into manifold project. Had to make up new braided lines, ran into a few small annoying issues but as of 2 hours ago it is up and running, did a 50k test drive which took in my two long test hills, EGT likely dropped by another 10c on those long climbs (same weather conditions as the last test of pre IC injection so comparable), then came back to my flat ground test strip to do a series of time trials, very happy and a bit surprised, 4th gear 60-100k time has dropped by an average of .5 seconds, the surprising thing is these are small DO nozzles just as a test and it was straight water, I didn't put any Meth in last time I filled the tank. Of course I must consider water economy as I only have a 10L tank and I do a lot of trips but I think Snow 1 nozzles will be great. I did put the larger of the 2 DO nozzle into the port that feeds the back valves to give extra cooling there.
I'm happy with it, lot of fiddly work and I had to make some of it up as I went along, having the spare head and manifold sure helped but there is plenty you can't see under the IC and one thing caught me out, that was the underslung fan contacting one of the fittings to the top nozzle, I would drill the nozzle hole around 10mm lower than I did.
Followed procedure I wrote up earlier except that I added a piece of heater hose with 200mph tape to the vacuum cleaner to get closer to the drillings on the inside.Pilot holes, lots of grease on the drill, rags stuffed down the port and a small hyase attached to the vacuum cleaner.
Main tapping holes, again plenty of grease and around 3 separate drillings with more grease.
Tapping with even more grease again 3 different times. This was the easy one, the lower I couldn't (expectedly) get the T onto it so had to do it with a small spanner.
Nozzles fitted,
Hoses cut and assembled and Throttlebody back on. The nozzle I had originally in the TB removed and hole plugged, won't be using that again.
Pre Turbo WM injection system removed from inlet, won't be using that again either.
Assembled and ready to rock.
This is where I ran amok of clearance, the underslung IC fan was preventing the IC from being bolted down so I had to shorten the assembly by 8mm, drilling a bit further down the side would alleviate this as would using another nozzle style, the DO nozzles use the filter holder to secure the nozzle flow controller piece in place, other nozzles use a controller that screws in itself so no height issues, I cut the top off the filter holder and cut a screwdriver slot into it to hold it in firm. I don't use filters as I have an inline filter.
I can slip a ruler in between the nozzle bend and the fan housing so all good.
