1821 - 1830 of 1830 Posts
GUII ZD30DI Wgn
Discussion Starter #1,821 (Edited)
Upgrade of Pre Turbo Injection
Replaced the 5 corroded silver anodised braided hose connections in my WM setup with black seeing as the black ones had not corroded. Did a full pressure flow test on my newly drilled out Snow #1 nozzle, below is a vid on it, last night I tracked down a new Snow #3 here in Oz at a reasonable price, ordered it and will try that one first before moving up to my drilled out version, will do a flow test on it at 200psi when it arrives.
BTW if you notice drops of water coming out the back of the tubing during the test, this was from the push in nylon fitting, once the tubing has been pushed in a few times the seal isn't always 100% this was why I went to braided under the bonnet as I'm always playing.........
GUII ZD30DI Wgn
Discussion Starter #1,822 (Edited)
Upgrade of Preturbo Nozzle to Snow3.
Have done 2 x Covid 19 drives since restrictions were relaxed last weekend, so, we can drive 50k from home but if all the back tracks take 200k within that 50k limit that is fine, so great testing as we did a solid mixture of mountainous and flat terrain at varying speeds.
I've used just about every nozzle brand there is over the years, I like the Snow as they seem to atomise far better than the others I have tried, terrible company to get info from but great nozzles.
In recent weeks I've made a couple of changes to how the WM system works, first up preturbo has two starting parameters, boost must be a minimum of 12psi and TPS must be 28%, I think I can drop the boost a pound or two lower but TPS is about where it should be, doesn't come on cruising but the moment a bit of effort is required it snaps on. The Throttle Body nozzle (DO2) comes on now at 17psi ramping to 19psi full on instead of starting at 19psi. The reason I reduced this was I had been cruising at 15-16psi which meant it jumped to 17psi very easily, I'm very happy with the mode I've set the digibooster at but would like a lower cruising boost (fuel eco). I reconnected my in cab needle valve and with the valve cracked around 1/2 turn I'm cruising at 11-13psi but as soon as load is exerted it responds the way it always has, if WOT is applied it shoots to 26psi immediately relaxing to 25psi, but under normal driving conditions it dances to the tune of throttle setting.
The first drive was with new settings but still Snow2 nozzle pre turbo (with system cleaned and new black fittings in place) very happy with performance and driveability. The second drive was with the new modified inlet and the new modified Snow3 nozzle. Note: The nozzle is still set within 4mm of the compwheel shaft.
New Snow3 compared to modified Snow2
519176
Had drilled out a Snow1 to 0.7mm to see what happened, got flow rates of just over 300ml/min at 200psi as shown in earlier video. Machined the new Snow3 to slimline and ran a 1/4"UNF tap through the back, rigged it up and bugga me I get the same flow readings even though the nozzle hole is ever so slightly smaller, this really shouldn't be according to Snow flow figures??? Took pics of both new and drilled showing spray pattern, the thing that stands out is the better atomisation of the Snow3. I know CM does all there flowrate testing at 100psi, I am not sure what pressure Snow does it at and I'm not sure David would pass that on considering past communications with him.
Snow1 drilled to 0.7mm
519177
Snow3 nozzle
519179
Snow2 nozzle
519185
Each Snow nozzle has a different internal flow manager as seen in pics below, I swapped the Snow1 device into the Snow3 nozzle thinking I would see a different flow rate, but no just a different pattern. Note: to make the nozzles fit my pre turbo the filter is dispensed with and the spring needs to be cut but I do cut them so the same compression is on the back of the plunger.
Snow1 plunger
519180
Snow2
519181
Snow3
519182
Snow2, cut spring with plunger and nozzle
519183
Did another inspection of the turbo while changing to the new inlet, all good once more.
519184
The outcome is the Snow3 improved driveability, the natural torque of the engine gets it moving fine and when the pre turbo comes in it just adds to it, the way I have it setup now means often the pre turbo comes on before the Throttle Body nozzle is activated.
Yesterdays drive was again a mixture of flat and mountains, something I'm still coming to grips with is I expected water usage to skyrocket, but it didn't, my only explanation is even though more is going in at any given time it must be on for less time due to efficiency.
GUII ZD30DI Wgn
Discussion Starter #1,824
Fantastic Rosco! I don't know if my bus will ever reach your level but I owe everything I know about my ZD too you, keep it up. Thanks mate.
I stand on the shoulders of giants.....
Thanks mate, I really appreciate that, makes everything worthwhile. Sharing what we have learned about our vehicles is what this forum is all about, while ever I have the enthusiasm to do projects I'll keep documenting.
Thanks again
Nissan patrol GU
Ross, have you tried your set up with throttle body first and pre turbo at second stage ??. Just curious if it would make any difference in power hit and water usage.
GUII ZD30DI Wgn
Discussion Starter #1,826
That is the way it was for many years, it is only in recent months with dropping TPS setting down to 28% and then dropping safety pressure down to 12psi that the reverse happens under certain circumstances, it does not happen every time like that because conditions change, ie taking off from lights will see pre turbo come on first due to heavier use of throttle, but out on the highway it takes a lot to get TPS to 28%. I think it has been a positive move. Water usage was my main reason for doing it the original way, but as found my water usage has not increased like I had expected.
Nissan patrol GU
So now chance of pre turbo being small nozzle and throttle body large nozzle is what l’m getting at , l know it sounds silly but , as said just looking at all possibilities.
GUII ZD30DI Wgn
Discussion Starter #1,828
There is more benefit pre turbo than post turbo, when I was cleaning out the system throttle bottle was a big one, at one stage I was injecting 7gal/hour to hasten cleaning. Improved driveability is what I chase now but still having wm economy in mind, and that is still looking positive. I actually have 3 injection points, post turbo I can switch between higher flow for around town and an economy for trips.
Nissan patrol GU
Totally agree, 👍👍
GUII ZD30DI Wgn
Discussion Starter #1,830
Performance Update
A year has well and truly passed since I last did this testing before the remap update, which is coming up on a year, so I suppose it's time to update some info, the old girl just gets better and better and considering that except for the remap all the mods I've done anyone can do in their backyard.
Did not bother with 0-100k time as it is really pointless, for touring it is what you can do in higher gears when out on the highway, so here goes in 4th gear:
60-80kph = 3.52 seconds
80-100kph = 3.62 seconds
60-100kph = 7.14 seconds.
100k cruise is now at 12-14psi on flat road instead of the previous 15-17psi, EGT is sitting nicely at high 200's and will rise to 400c when loaded, no problem, of course if I push it hard up a reasonable incline (like the last climb coming up towards Monteville) it will go to 500c and recovers instantly.
Boost still set at 25psi, will spike to 26psi on WOT but drops straight back to 25psi. ICV% has come down while cruising, instead of 3.75v it is now 3.55v. and I'm back into low 11L/100k with all the gear still on and in it.
