1 - 9 of 9 Posts
I have a large stock of new genuine Nissan Safari parts. These were bought for our 1991 Nissan Safari 4wd grand road, built 11month of 1991. TD42 diesel, 5spd standard. Vin # VRGY60-623201.All parts were ordered in the past 7 months for this truck through Nissan fast, genuine parts catalog. Most parts were brought in through Nissan Canada, with some brought in through Patrolapart, Partsoug and Rocky mountain imports.
We planned on keeping this Safari for a long time (Hence all the spares) but things changed and we needed to buy a diesel firewood truck.
All parts are in original Nissan boxes and sealed bags. Let me know if you want photo's of any parts or assembly's.
Prices- All parts are 35% off what I paid before tax and 45% off, if you buy in a package. I have all original receipts as well. Call for prices Michael 250 753-2392.
For parts cross reference look up your vin on these sites.
VRGY60 / nissan | fig list?JP-CarParts.com
www.partsoug.com and Nissan fast parts catalog.
Also most original part numbers sublist to newer safari/patrol part numbers within the Y60 family, this is why it's good to cross reference:)
As parts sell, I will remove them from the post.
Thxs
Cooling system
Genuine Nissan radiator 21410-1Y11A
Genuine Nissan cooling fan 21060-06J10
Genuine Nissan top heater hose 21501-06J00
Genuine Nissan bottom heater hose 21503-06J00
Genuine Nissan heater core hose 92410-06J10
Genuine Nissan heater core hose 92400-06J10
Radiator cap Drive Joy Japan V9113-CS09 (CS-09)
Genuine Nissan heater core 27140-41L11
TD42 DIESEL ENGINE ELECTRICAL, SENSORS AND RELAYS
Genuine Nissan 24V starter 23300-06J04
Genuine Nissan starter relay 24V 25230-C8000
Genuine Nissan 24V alternator rebuild kit
Electrical board-alternator 23230-11T03
Terminal ASSY-E and brushes 23528-C8601
Bearing 23129-05E06
Bearing 23120-97E00
Genuine Nissan windshield washer motor 28920-50Y00
NGK Japan glow plug set, 24V 4018 Y-757RS
Genuine Nissan relay assy-glow plug 24V 25230-06J10
Genuine Nissan heater fan relay 24V 25230-01J00
Genuine Nissan ignition switch assy 24V 48750-AD000
Genuine Nissan relay ignition 24V 25230-01J00
Genuine Nissan flasher assy 24V 25730-05J00
Genuine Nissan coolant temp sensor 24V (on engine block) 25080-89903
Genuine Nissan coolant temp sending unit 24V 22630-10G00
Genuine Nissan oil pressure sending unit 24V 25070-0Y710
Genuine Nissan link-fusible 24V 24370-89960
Genuine Nissan link-fusible 24V 24370-89900
Genuine Nissan link-fusible 24V 24370-89905
Genuine Nissan link-fusible 24V 24370-89910
TD42 Engine parts
Genuine Nissan head bolt set 26 piece set 11056-09D61
Genuine Nissan head gasket 11044-06JO1
Genuine Nissan valve cover gasket 13270-06J01
Genuine Nissan vacuum pump assy complete 14650-02N07
Genuine Nissan exhaust gasket set 14036-06J02 x2, 14036-06J03 x4
Genuine Nissan exhaust gasket down pipe 20691-01P80
Genuine Nissan power steering pump seal kit 49591-50L28
Genuine Nissan rear crankshaft oil seal 12279-43GO2
Genuine Nissan vacuum pump rebuild kit
O-ring 14688-61503
Copper washers 3 piece 14681-37600
Pump vanes 4 piece 14652-W2500
Copper washer 1 piece 14684-61503
O-ring 14688-W2500
Fan belt (Pitwork Japan) AY16N-VH140
Power steering belt (Pitwork Japan) AY16N-VH255
A/C belt (Pitwork Japan) Ay16N-VH950
BRAKE SYSTEM
Genuine Nissan master cylinder assy 46010-02J00
Genuine Nissan brake booster assy 47210-32J00
CLUTCH SYSTEM
Genuine Nissan clutch booster assy 30630-37J05
Genuine Nissan clutch master cylinder 30610-37J21
Genuine Nissan clutch slave cylinder 30620-34J20
Genuine Nissan emergency brake cable assy 36402-01J00
Genuine Nissan center emergency brake shoe set 36160-C9625
Exedy AUSTRALIA clutch kit NA22AGY60
Genuine Nissan throw out bearing 30502-V6200
TRANSMISSION / TRANSFER CASE
Genuine Nissan input trans seal C2219-Z5004
Genuine Nissan output trans seal 32136-01J00
Genuine Nissan trans shift socket assy 32850-V5001
Genuine Nissan trans bush control le 32861-01G00
Genuine Nissan trans shift rubber boot 32862-05U00
Genuine Nissan clutch fork dust cover 30542-01J00
Genuine Nissan transfer case rubber boot 32859-33G02
Genuine Nissan transfer case rubber boot (middle) 32859-01J00
Genuine Nissan transfer case input seal 33111-01J00
Genuine Nissan transfer case rear pinion output seal 33142-01J01
Genuine Nissan transfer case front pinion output seal 33216-33G01
FRONT AXLE REBUILD KIT
Genuine Nissan diff gasket 38320-T3322
Genuine Nissan front dust seal x2 40227-C8200
Genuine Nissan front pinion oil seal 38189-C7122
Genuine Nissan front bearing knuckle assy x4 40030-VBOOO
Genuine Nissan front comp bearing needle x2 40588-C6000
Genuine Nissan front plate spindle x4 40040-01J00
Genuine Nissan front inner seal x2 40533-01J00
Genuine Nissan front bolt stop x2 40038-J0160
Genuine Nissan front inner bearing assy x2 40215-C6000
Genuine Nissan front outer bearing assy x2 43210-C9300
Genuine Nissan front axle bearing lock washer x2 43232-45460
Genuine Nissan front hub seal x2 40232-01J00
Genuine Nissan front O ring hub dust seal x2 40228-01J10
Genuine Nissan front axle large swivel ball grease seal x2 40579-01J00
Genuine Nissan front wheel hub bolts x12 40222-C6000
REAR AXLE REBUILD KIT
Genuine Nissan rear diff gasket 38320-T3322
Genuine Nissan rear oil pinion seal 38189-C7123
Genuine Nissan rear axle bearings x2 43210-01J10
Genuine Nissan rear O ring axle seal x2 43085-01J10
Genuine Nissan rear hub grease seal x2 43232-01J10
Genuine Nissan rear axle shaft seal x2 43252-C6001
Genuine Nissan rear wheel hub bolts x12 40222-C6001
BODY
Genuine Nissan left rear mud guard 78811-33J25
Genuine Nissan front side bumper bolt x1 01135-00561
Genuine Nissan left rear door finisher (Gray) (Top arm panel) 82903-51N01
Genuine Nissan grille speaker x2 28176-50A02
Genuine Nissan door panel clips x10 80999-VE000
New windshield from Rocky mountain imports
naturally asthmatic
Well with a list like that, it would be hard to follow the Patrol4x4 classified rules but you should put a price on each item. It will save both you and potential buyers time. Good luck with your sale.
Safari Hoarder
Sitka, thanks for posting this. I will be buying a few when my head is clearer. Please try and update when you can. As far as I am concerned you have posted you bits as well as you could and this is not the "classifieds" section.
Nissan Safari Genuine parts list prices
All prices marked are what I paid before tax and shipping. All parts came from New Castle Nissan, Patrolapart, Rocky mountain imports and Partsoug.
One part 35% off marked price
Four parts or more 45% off marked price
All the parts in a kit, 50% off marked price
No tax
All shipping and payments can be done at Canada post. Ask for any photo's.
Thxs
Cooling system
Genuine Nissan radiator 21410-1Y11A $690.88
Genuine Nissan cooling fan 21060-06J10 $145.22
Genuine Nissan top heater hose 21501-06J00 $45.09
Genuine Nissan bottom heater hose 21503-06J00 $60.23
Genuine Nissan heater core hose 92410-06J10 $18.45
Genuine Nissan heater core hose 92400-06J10 $24.89
Radiator cap Drive Joy Japan V9113-CS09 (CS-09) $20.16
Genuine Nissan heater core 27140-41L11 $302.04
Genuine Nissan 24V starter 23300-06J04 $1078.31
Genuine Nissan starter relay 24V 25230-C8000 $54.19
Electrical board-alternator 23230-11T03 $203.54
Terminal ASSY-E and brushes 23528-C8601 $275.03
Bearing 23129-05E06 $48.79
Bearing 23120-97E00 $25.81
Genuine Nissan windshield washer motor 28920-50Y00 $42.87
NGK Japan glow plug set, 24V 4018 Y-757RS $468
Genuine Nissan relay assy-glow plug 24V 25230-06J10 $69.50
Genuine Nissan heater fan relay 24V 25230-01J00 $34.37
Genuine Nissan ignition switch assy 24V 48750-AD000 $59.22
Genuine Nissan relay ignition 24V 25230-01J00 $34.37
Genuine Nissan flasher assy 24V 25730-05J00 $52.70
Genuine Nissan coolant temp sensor 24V (on engine block) 25080-89903 $42.63
Genuine Nissan coolant temp sending unit 24V 22630-10G00 $62.48
Genuine Nissan oil pressure sending unit 24V 25070-0Y710 $111.11
Genuine Nissan link-fusible 24V 24370-89960 $14.71
Genuine Nissan link-fusible 24V 24370-89900 $14.67
Genuine Nissan link-fusible 24V 24370-89905 $15.36
Genuine Nissan link-fusible 24V 24370-89910 $14.67
TD42 Engine parts
Genuine Nissan head bolt set 26 piece set 11056-09D61 $121.94
Genuine Nissan head gasket 11044-06JO1 $88.74
Genuine Nissan valve cover gasket 13270-06J01 $71.78
Genuine Nissan vacuum pump assy complete 14650-02N07 $472.25
Genuine Nissan exhaust gasket set 14036-06J02 x2, 14036-06J03 x4 $111.60
Genuine Nissan exhaust gasket down pipe 20691-01P80 $10.10
Genuine Nissan power steering pump seal kit 49591-50L28 $30.81
Genuine Nissan rear crankshaft oil seal 12279-43GO2 $31.20
O-ring 14688-61503 $7.92
Copper washers 3 piece 14681-37600 $5.07
Pump vanes 4 piece 14652-W2500 $124.24
Copper washer 1 piece 14684-61503 $3.04
O-ring 14688-W2500 $15.30
Fan belt (Pitwork Japan) AY16N-VH140 $31.88
Power steering belt (Pitwork Japan) AY16N-VH255 $33.66
A/C belt (Pitwork Japan) Ay16N-VH950 $31.88
BRAKE SYSTEM
Genuine Nissan master cylinder assy 46010-02J00 $652.80
Genuine Nissan brake booster assy 47210-32J00 $1134.18
CLUTCH SYSTEM
Genuine Nissan clutch booster assy 30630-37J05 $536.14
Genuine Nissan clutch master cylinder 30610-37J21 $99.65
Genuine Nissan clutch slave cylinder 30620-34J20 $189.84
Genuine Nissan emergency brake cable assy 36402-01J00 $74.46
Genuine Nissan center emergency brake shoe set 36160-C9625 $68.48
Exedy AUSTRALIA clutch kit NA22AGY60 $510
Genuine Nissan throw out bearing 30502-V6200 $58.24
Genuine Nissan input trans seal C2219-Z5004 $25.60
Genuine Nissan output trans seal 32136-01J00 $13.15
Genuine Nissan trans shift socket assy 32850-V5001 $35.20
Genuine Nissan trans shift rubber boot 32862-05U00 $16.15
Genuine Nissan clutch fork dust cover 30542-01J00 $10.33
Genuine Nissan transfer case rubber boot 32859-33G02 $8.73
Genuine Nissan transfer case rubber boot (middle) 32859-01J00 $14.30
Genuine Nissan transfer case input seal 33111-01J00 $13.35
Genuine Nissan transfer case rear pinion output seal 33142-01J01 $38.75
Genuine Nissan transfer case front pinion output seal 33216-33G01 $24.15
FRONT AXLE REBUILD KIT $401.09 total
REAR AXLE REBUILD KIT $176.74
BODY
Genuine Nissan left rear mud guard 78811-33J25 $228.10
Genuine Nissan front side bumper bolt x1 01135-00561 $6.33
Genuine Nissan left rear door finisher (Gray) (Top arm panel) 82903-51N01 $89.33
Genuine Nissan door panel clips x10 80999-VE000 $45.70
New windshield from Rocky mountain imports $313.60
Well thanks to all the bought parts. Here is an updated list as of Tuesday Aug 5, 2014
No tax
Thxs
Cooling system
TD42 Engine parts
BRAKE SYSTEM
CLUTCH SYSTEM
BODY
Here is an updated list, as of Tuesday Aug 24, 2014. Thxs to all Nissan Safari 4wd owners who bought parts.
No tax
Thxs
Cooling system
TD42 Engine parts
BRAKE SYSTEM
CLUTCH SYSTEM
BODY
Discussion Starter #8
Here is an updated list, as of Friday September12, 2014. Thxs to all Nissan Safari 4wd owners who bought parts.
No tax
Thxs
Cooling system
TD42 Engine parts
BRAKE SYSTEM
CLUTCH SYSTEM
BODY
Discussion Starter #9
Here is an updated list, as of Thursday October 23, 2014.
All parts 50% off marked price.
NO TAX....
Thxs
Cooling system
TD42 Engine parts
BRAKE SYSTEM
CLUTCH SYSTEM
BODY
1 - 9 of 9 Posts
