gf0012-austs mav and troll
47522 Views 276 Replies 36 Participants Last post by  gf0012-aust
2
Red:
89 LWB Maverick, 31"s, set up as a tourer, TB42
Stumpy:
90 SWB GQ, 32" muddies, dobinson springs, 3" lift, TB42: dual fuel, 9000lb warn, ARB rack and bully
date stamps wrong as the camera zeroed to default date
1 - 20 of 277 Posts
changed the host to photobucket - now works properly
2
Installed the first gas strut:
toyota hi ace struts, they are already fitted with brackets so literally a bolt in job once you find spare (and solid) real estate in the engine bay.
hey mate where did you get that gas strut from or what off??
its for a toyota hi-ace.
bought it through ebay.
I chose the hi-ace struts because they're designed for a heavy load and the fact that they already have hinges mounted on them, so no need to dick around with ball mounts etc....
$59 for both struts..
the second strut will be fitted on the weekend once I clear the wiring around the master cylinder...
fitted an N13 Twin Cam steering wheel into Red..
Land vehicle Vehicle Car Steering wheel Steering part
$13 wheel puller
$20 for the wheel
removed centre nut with a wheel brace (17mm)
tightened back on using long socket and a 1/2" bar for leverage
horn connections are the same...
Hey mate do you have closer pics on how you have mounted the struts
I've taken it off since Trav suggested that it might exert too much pressure and warp the bonnet.
I'm currently trying to find 2 x smaller units that aren't exerting so much poundage.
the hi-ace strut was pretty impressive, it would pop the bonnet upon release and once uncatched would send it straight up.
when I had the hi-ace strut on I placed it against the strongest part of the firewall and then lined it up against the bonnet at full supported extension (ie with original support bar in place)
3
Tradesman rack fitted to the Mav
rack off a 96 Jeep Cherokee - unfort not a perfect fit as cherokees are smaller in width (by a fraction) - and the width between the front and rear-most bars on Mavs/Patrols is not "square"
the trademan racks are a full gutter skid, so not as flexible to line up, but better load bearing
cyclonic installed on the shorty
Land vehicle Car Vehicle Automotive exterior Tree
Tradesman roof rack on the mav
Land vehicle Vehicle Car Automotive tire Tire
Nice mods. I´m realy liking the struts to hold the hood. I´ll think i´ll steal this idea and put some struts under my hood ;)
replaced spotties after stones buggered up the lower ones
Land vehicle Vehicle Car Bumper Automotive exterior
replaced the water pump on shorty:
check out the vanes... odd as no metal lying around in the sump etc...
Auto part Vehicle Wheel
awesome mate,what size tyres.
they're only 31x10.5xR15's
Not shabby for a "stock size"
they're retreads, but its not as if I'll be doing 110+ in them.. :)
sweet projects ya got there mate. thought they need to get dirty mate! any wheeling pics?
1 - 20 of 277 Posts
