1 - 2 of 2 Posts
Nissan patrol GU
I’ve tracked my issue to the glow plug relay, does it require any special procedures to remove just unbolt clear cover and unplug ??.
Nissan patrol GU
Discussion Starter #2 (Edited)
Update, replaced today, pretty easy, just the lack of room . (Disconnected battery first)Removal of green plug easy , the two white ones are a little tricky. I bolted relay back on bracket,press down on ends of plug and wiggle out, they are pretty stiff so wiggle side by side with CARE. Don’t mix up when re installing .
Reactions: Knuckles
1 - 2 of 2 Posts
