1 - 8 of 8 Posts
G'day all, i recently had my clutch master fail draining all fluid out of top up bottle. I replaced it with new non genuine master and top'd up fluid and bled, but now i have no vacuum assistant. I check vacuum and its sucking fine and everything was working properly before i put new master on. Could i have done something? Only thing i may have wrecked was outer rubber seal on clutch servo where the push rod is.
Also it changes gears fine its just bloody heavy.
Any ideas would be great!
cheers brent
Need to fix that rubber boot. also where did all your leaked brake fluid go? its not inside the booster is it? I'd be whipping it off and giving it an overhaul.
Got mine rebuilt cost $220
got a price for a new one from Nissan $1800
I had a booster that ripped a diaphragm and the pedal goes bloody heavy. Much heavier than the non booster type. I think I paid around $160- $180 for an exchange one.
Yer im thinking the booster is full of fluid unfortunately aye, there was alot of fluid lost when it failed. is it best to too take to brake/clutch place to be rebuilt or do urself?
Cheers brent
1 - 8 of 8 Posts
