1 - 11 of 11 Posts
Hi guys, im trying to disassemble the cv's on GQ patrol to repack them with no success.Tried the slide into a length of pipe method & in a vice with a hammer & drift. Any idea's thanks
GHMBC #3
nissan patrol gq lwb,3"lift.
ok don't try and take the axle out of the 'cup'.axle is held in with a clip that is very hard to dislodge.repack while together.if existing grease is contaminated blast out with a degreaser gun till clean,flush with kero,hang up axle end down to dry then repack with fresh grease
Thanks Gas that was my next idea. What i've seen and read on searchs it just pulls apart! Not this one. Thanks mate
GHMBC #3
yeah never seen one come apart without a grinder lol
GHMBC #3
on another note- if you have less than 10mm axle end float you 'apparently' don't need the clip on the axle which would make changing a c.v easier.with a locker installed most stop the axles going in towards each other at the diff centre and have no need for the clip to be fitted,I installed a set of Dirty 30's axle and birfield joints and measured end float-was only a few mm but clips are on.
I do have an air locker. Hope i didnt damage the clips trying to get it apart. It still only has mm axle movement in the cup. Should be right. Fingers crossed
First and last one I separated damaged the end of the spline where the clip fits (inside the cup). As said give it a good clean and repack with cv grease.
Reactions: GQ QLD
Cheers Paddy that will be the go. The other searches i found must not be GQ cv's
Nissan Safari
You need to have the stub axle at a hard angle to the axle. Get a block of wood and put it over the cv. Hit it very hard with a hammer. Should pop the cv over the clip. I have always used this method and I have changed a few cv's out bush because of snapped stub axles with a lokka.
1 - 11 of 11 Posts
