1 - 7 of 7 Posts
I have 2" dobsons springs and when the front is near full droop, the right hand spring jutters as i think the spring moves in the bottom or top locator.
its like the spring is too loose?
Is there a clamp you fit to hold them in place or should i look elsewhere for the fix??
I wouldn't worry about it. The springs at full droop will get a big bow in them and cause them to bounce around. Mine does it as well. Or get something like a plastic spring wrap and wrap it round. Will quieten it down
You could retain top and bottom of the springs to the mounts if you wanted. The top should have a rubber insert that sits between the spring and the mount to stop this noise but this means the bottom can still make this noise.
When I put my toy on the hoist it sounds like a piano falling down stairs. dont worry about it unless it REALLY annoys you.
hmmm, was looking at the plastic retainers cos the sound doesn't bother me, just the passengers :)
When mine's on the hoist there is about a 50mm+ gap above the springs. They've never dropped out though. They make heaps of noise when they settle too.
1 - 7 of 7 Posts
