just wondering if these gearboxes are the same and whether it will fit straight into a td42 ute
nissan patrol gq
yeah it would i was reading about a mates car in a 4wd action mag and he said that he had a 4.2 diesel 1988 swb and he put i 4.8 gu petty in it. while your there you should upgrade the standard clutch.
The box itself is the same, bell housings are different. So if you have your TD housing your right. I think its more for the starter then anything.
You can drill and tap a petrol bellhousing onto a diesel starter motor but not the otherway round.
But if you have a bellhousing to suit yeah tb/td gearboxes are the same
