1 - 3 of 3 Posts
G'day guys.
I have a TD42 with twin Z115 oil filters. I know some models had two different filters fitted.
Does anyone know if the oil supply is the the same or different to each filter, ie pressure or volume?
Does one filter do a different job to the other?
I am going to remove one filter and replace it with an adapter for a single bypass oil filter such as the Baldwin B50. I want to kmow which filter is the best to remove. I know I can leave it there and feed the bypass filter off the pressure switch but I don't want to do this.
Discussion Starter #2
I am sure I have seen this mentioned somewhere in here before.
Any ideas guys?
Ok.
Next question then. Who has a TD42 with different filters?
What filters are they and which one goes front and rear?
Why are they different on this engine, is one supposed to be a bypass filter?
1 - 3 of 3 Posts
