1 - 7 of 7 Posts
nissan/patrol
Hi All,
The Starter Motor is shot and I need to replace it. My service manual indicates I have an S13-118 model starter.
I have been looking on ebay for a replacement and saw an add for a 3.2KW starter. It is an S13-118A. Earlier posts in this forum say that GQ TD42 users have used this model starter, but I am concerned as the pinion shaft seems to extend further than the S13-118 model.
I have included a pic of the two models. Can someone confirm if either model will fit my patrol please?
Regards Mark
Nissan patrol gq
Iv got the same problem and was wondering about that same starter motor on ebay if you find out anything could you let me no
i bought the right one from ebay(exactly the same) and fitted it to my td42 with out a problem.i think the shaft would bottom out on the back of the bell housing recess
looking at the photos, those 2 starters are very different configurations, not just in the shaft but also of the orientation of the motor/solenoid. I believe the one of the right with the short shaft is the standard configuration for my ute.
cost of an overhaul tends to exceed the cost of a new chinese unit, plus the down time.
I made 1 good one out of 2 bad ones, then bought a new Hitachi one for over $600. The hitachi units are meant to be better and more resilient to water ingress.
1 - 7 of 7 Posts
