Nope. Genuine GQ ones.Are they the 79 Cruiser mirrors????
Which factory mirrors do they replace? The manual mirrors mounted on the door with 2 bolts? The electric mirrors mounted in the corner of the windscreen? I can already see it's not option 3 (older GQ utes with triangular draft windows)Nope. Genuine GQ ones.
Yep the manual mirrors mounted on the door with the 2 bolt. You need to drill a third and fourth hole to secure them. They come with a backing plate. Pretty new on the market. I'm stoked as I tow a 15ft Jayco with my gq and the old towing mirrors were magnetic and use to scratch the door.Which factory mirrors do they replace? The manual mirrors mounted on the door with 2 bolts? The electric mirrors mounted in the corner of the windscreen? I can already see it's not option 3 (older GQ utes with triangular draft windows).
Cheers mate. Pretty stoked with emThey look good mate. Be much better then the generic ute mirrors that I have.
YesThese are OCAM mirrors.
I just purchased these for my 96GQ ute and they match up with the original bolt holes on the triangle mounting bracket. OCAM Extendable Towing Mirrors For Nissan Patrol GQ Y60 1988-97, ManualWhich factory mirrors do they replace? The manual mirrors mounted on the door with 2 bolts? The electric mirrors mounted in the corner of the windscreen? I can already see it's not option 3 (older GQ utes with triangular draft windows).
