hey guys just need a little help I went 4x4ing last weekend to five rocks up big sandy ( big sand hill) my 2.8 temp reached 110c i was pushing it in low range peaking out 3rd but isnt the first time never normally leaves 82c I puled up let it cool off its been fine since what is the max temp u can push a 2.8 the stock gauge didn't move
I have a front mount intercooler
chip
exhaust
boost is at 22psi
egts don't go above 450c
33x12.5 r15 mickey mtzs
Damn 22psi?!
I've had my 2.8 up to 104-105ish, mid 30's ambient temperature, towing 2 tonnes.
I take it you have a ecutalk or similar?
FYI, when mine was 105ish, It was showing a bit over half on the gauge, but nowhere near the red.
With a stock turbo 22psi is not really great.
Turbo is well out of its efficiency range.
Justin
Justin
thanks guys
yeh inlet tempretures don't get that high guess the front mount makes up for it its not a small one
using ecu talk and temp sensor in the top hose
If u havent had ur radiator done I would suggest u do as the 2.8 are prone to cracking heads.
Mine never used to aboue 90 (ecu talk) after I had radiator cleaned and new head fitted.
Might even pay to check ur fan as if its low speed sand work ur fan shoukd have locked up too
They are designed to run at 110.
The issue is you are getting close to absolute maximum.
So if you are at that temp you need to keep an eye out.
Mine has been up to 110 on a very steep very long hill climb on road.
Flat in 3rd and it was so steep I nearly changed down to second at the top.
It's never got to 110 even after a day in the dunes at Robe in plus 35 degree heat.
Justin
