Has anyone ajusted the valves on a gu 2.8 i have done 230000 kms and still going strong . I was wondering if they close up.
curly,curly said:Has anyone ajusted the valves on a gu 2.8 i have done 230000 kms and still going strong . I was wondering if they close up.
Valve clearances normally get tighter not looser over time & with the correct tool to depress the lifter & a selection of shims shim ajustable valves are fairly simple (on toyota's anyway) as long as long as the cam doesn't have to be removeditchyvet said:curly,
Can't see how they would "close up", now if you were talkin about "OPENING UP" I'd reckon you may have a point.
Whatever, I have not personaly come across any Nissan Mech who looks upon such a job with pleasure, in fact all my discussions with them, usually reveal contempt and replies such as," don't need to be done, she'll be fine" ect.
Yet the workshop manual clearly states they need to be done regularly.
Maybe the factory's got it WRONG ?
I do know, you need special tools to do the job and it would also appear, some knowledge and know how of how to do it properly, that leaves out every Nissan Techi I know of, and a host of other Mech's I know as well.
In fact I have not yet come across one that's capable of doing the job as described in the manual.
Even the cases wherein people have their 2.8's rebuilt, NEVER is mention made of the tappet adjustment and shimes replaced. Funny that.
Tis true, to a point.itchyvet said:One small point, my experience with combustion engines I've found the tighter tappets get, the less noise they make, and conversly, the looser they get, the more they rattle.
Where's that then ?itchyvet said:Yet I'm being told exactly the opposite here.
Rattles as a diesel should or rattles as in tappety ?itchyvet said:And seeings as my 2.8 rattles like buggery, I take it the clearances are tops ?
TomTracteur Tom said:Tis true, to a point.
Where's that then ?
Check the valve clearances as said. The reason the clearances close up is due to the valve slowly sinking into the head. This is balanced with the tappet/cam gear wearing. So you can find the gaps closing up or increasing. With a OHV set up the adjusters tend to work loose, there is also more (compared to OHC) interfaces to wear so the gaps increase. With a OHC with hydraulic tappets the gaps tend to tighten up - a broad generalisation, you must understand !
