G'day.
Plenty of good info on the airbox swap, so I have grabbed one to fit when the time comes to fix my intake piping.
When I received the airbox I found that one of the factory moulded plastic mounts has been broken off the bottom of the airbox. Out of the 3 plastic mounts it is the single one mounted up higher than the other two.
I am not ready to do the swap yet, so I don't want to pull my airbox out just to check this. Do I need this plastic mount to fit the airbox to the GQ, or does it just mount using the other brackets?
Cheers,
Shayne
Cheers,
Shayne
