Hi folks my air cond compressor seems to have stopped. From working very well on my last drive about 3 weeks ago it, the compressor isn't cutting in anymore. The usual issues of water and mud entry problems don't apply in this case.
I have checked for refrigerant leaks, under dash fuse, swapped relays, pulley belt and unclipped (thinking of a bad connection) checked and plugged back in the connection for the pressure switch and the connection on the compressor.
Apart from that I don't know what else to try. The wire which runs from the back of the alternator to the compressor is a single wire, is it a 12 volt wire? I was going to try and stick a multimeter in it to see what happens.
The blue air cond light in the dash switch activates but that is about it.
