1 - 8 of 8 Posts
Does anyone know the airbag that airbag man uses in their coil cab kit vs the wagon, I know the wagon uses 5422, does anyone know if the brackets are the same for wagons and utes and where's the best place to buy airbags from?
· Administrator
Not sure where you are located but Air Bag Man has 2 stores in Brisbane, I would go directly to them even if just to ask the question. My first bags destroyed themselves after a few years, can't remember brand but they weren't air bag man, changed to them and never looked back.
Discussion Starter · #3 · (Edited)
Wasn't sure how helpful they would be seeing as I picked the wagon kit up second-hand but the girl was helpful. Apparently the bag is the same but the upper bracket is different, so getting a quote for new brackets, but I am surprised that tye upper bracket would have to be different given you can buy bolt in speing hat reinforcement that suit both
· After Monday and Tuesday, even the calender says W
06 Td42ti coil cab chassis
I have airbag man in my coil cab..
As gee said, great gear.
I agree with Geeyutoo and 45/70, great stuff, ours have been in 15 years and done multiple deserts, all over the north and Vic High country with a camper on the tray. The worst I've had is a leaking valve seat.
Do you know what airbag you use? What loft are you running
1 - 8 of 8 Posts
