My dash lights are not working when I try my headlights on, I've checked the fuse and it's good, someone told me it has something to do with the earth in the standard radio loom, and when fitting a after market head unit to run a new earth, anyone had this problem before?
If you pick the wrong 'earth' it turns into 12v when the lights go on. Best to run your own.
Are the parkers/tail lights working?
Sent from my GT-I9100 using Tapatalk
Think I've got a similar problem. I put a new head unit in this afternoon and I've lost operation of my electric antenna , lost my dash lights , I've lost parking lights and tail lights. I used all the adapters that were sold to me and was told I needed. In disconnecting the standard ( factory ) wiring and adding the adaptors , have I eliminated or created an earthing issue? Or could it be blown fuses? I personally have had trouble working out which fuse does the dash lights, antenna etc.
Yeah used the adapters aswell, I'm going to run I separate earth and see if it fixes the problem
