gu 5L engine conversion.
hey guys.. have been doing some searches but have come up kinda at the same result which hasnt answered my question.
i am considering a engine conversion for my GU but was going to put a holden 5L engine instead of the LS1/2. and before you ask yes i have looked into both and i have made my decision. the cost of the LS1/2 outweighs the benifits over the 5L as far as im concerned.
i have heard a few people say that you have to use an engine as old if not newer then the car your putting it into.. i havent heard this before and i have seen a GU with a 5L in it but mostly its GQs.
has anyone put a 5L into a GU and if so can you give me an idea of what the end results were and any info that will make my decision easier.
if it helps the GU has a 2.8L and i was going to replace the manual with an auto with the reduction gears in the transfer case.
i have a budget of around $7K and will be able to do pretty much everything myself. (might need a hand with the electrical side.... im a black hander).
also how roughly am i looking at for an engineers cert. i have never had to deal with one before...
dave
dave
